can the pll locked signal of the max10 be used as the reset signal ?
Thanks for your help,
and the information mentioned in the figure below applys to max10 or not ?
and there are no INIT_DOWN and nINIT_DOWN signal, is there any other signal can be used as the init done signal for the max10 ?
- zlan015 years ago
that is I want to implement the similar reset circuit shown in the above figue in page 5 of AN 891, can I ?
- EngWei_O_Intel5 years ago
Hi Zhang Lan
Nope, this pin isn't available for Max10. Designers typically use an explicit reset signal for the design, which forces all registers into their appropriate values after reset. Intel recommends this practice to reset the device after power-up to restore the proper state.
thanks.
Eng Wei
- zlan015 years ago
and what is the explicit reset ? can you give me an example? please
the meaning of explicit is indistinct,right ? and how can I get a indistinc reset?
