8 years agoCan not program MAX7000
I can not program my MAX7000. I fell back to Quartus 13.0sp1 in order to create the POF. I can not get that POF into the part. The part I'm using is the EPM7064AETC44-10N The program...
8 years agoHi,
it is a Long time ago I had a MAX7000 design, but as far as I recall: The "TC44-10N" describes the chip type (TQFP), Commercial temperature grade, Speed and "N" was IIRC the indicator for "no Pb"... The programmer does not identify the complete physical configuration, i.e. "only" the familiy (MAX7000) and size ("064"). The only idea I can contribute is to check in Quartus that the correct device is assigned for the Project ("there" in the design process the complete type needs to be selected afaik) Maybe that helps, Carlhermann
