12 years agoCan not ping to the host
https://www.alteraforum.com/forum/attachment.php?attachmentid=8953 Can anybody help me with this problem. It says that "100% packets lost!" :(
12 years agoYour Linux can`t obtain IP address from DHCP system:
...Sending discover...
No lease, failing And "Link is Up" -- board`s cable is connected to network, all OK. Ask your system administrator, if DHCP configured strange. Best way -- Windows and Linux configured through DHCP. Or try set in Windows option "Default gateway" -- reply to ping go out to this IP, else rejected. May use "arp -a" in command prompt to display all recently (5 min) dialed IP- and MAC-addresses with your Windows. If see MAC 76:6C:73:63:4B:xx or IP 192.168.2.12, then ping damaged from Windows!
