RobertLiang
5 years agoCan I write a ".rpd" file that only contains the application image to an EPCQ device in RSU?
Hello experts,
I want to write a ".rpd" file that only contains the application image to an EPCQ device through "ASMI parallel IP" for remote upgrading the system (RSU).
The factory image has bee...
- 5 years ago
There shouldn't be any issue on writing the 2nd half of the flash if it is not overwriting the factory image (if you confirm that it is able to fit within the 1st half of the flash).
You can refer to design example from https://www.intel.com/content/dam/altera-www/global/en_US/uploads/4/4f/Remote_system_upgrade_c10lp_quick_start_guide.pdf
JohnT_Altera
5 years agoHi,
