8 years agoCan I use this trick for CPLD MAX V small MBGA package
Hello, I have designed a small board with a CPLD MAXV MBGA package(5M80ZM68I5) since I did not use all the pins and I did not want to use high tech board production which is expensive I u...
8 years agoHey Alex and FvM
I see a misunderstanding in my mesurments I check those pins again and this is the result: On the boards that have a problem, before flashing and when probing, TDI , TMS, TDO =3.3V, TCK = 0V. On the boards that do not have a problem, TDI and TMS= 3.3V, while TDO and TCK = 0V So please consider that those boards that TDO pin is 3.3V, we have problem Then what is your idea? still you think about assembly issue?
