8 years agoCan I use this trick for CPLD MAX V small MBGA package
Hello, I have designed a small board with a CPLD MAXV MBGA package(5M80ZM68I5) since I did not use all the pins and I did not want to use high tech board production which is expensive I u...
8 years ago --- Quote Start --- User I/O pins of an unprogrammed device should be high impedance. --- Quote End --- More exactly tri-stated with weak pull-up, up to 300 µA input current per pin according to datasheet. This should still allow JTAG operation, I rather suspect a solder fault or defective device.
