12 years agoCan I use Stratix V to realizing 28GHz asynchorous sample
One asynchorous control signal send to Stratix V ,the jitter must be less than 0.1ns.so the sample frequence must to be at lest 20GHz .what should i do? one way I think , can I use high spe...
12 years agoUsing the SERDES is probably not a good solution.
What exactly are you trying to sample? If you want to detect whether a pulse has occurred or not, you might want to consider using a high-speed flip-flop, eg., Hittite microwave has parts. Perhaps you could describe your application in more detail. Cheers, Dave
