16 years agoCan i use Jtag pins as I/O on MAX7128'S' device?
Hi All, I'm currently playing with some MAX EPM7128S-LC84 chips, ( i have bunches of them to use ). Currently i'm programming them via the JTAG interface (4 pins) and can access the rem...
16 years ago --- Quote Start --- If i assign the JTAG/IO pins within my design, will i still be able to program the device via JTAG? --- Quote End --- No you need a parallel programmer, e.g. Altera APU. If I remember right, it's mentioned somewhere in the datasheet. But it's obvious from the fact, that JTAG has no high voltage signalling to override an existing pin assignment that disables JTAG pins.
