Can I use 10M08 to Remote System Upgrade over UART with the Nios II Processor?
Thank you for the response Anand. I am trying to get the remote_update.c file to fit the 10M08 onchip memory. It says
Info: Linking nios2_rsu_sw.elf
nios2-elf-g++ -T'../hal_bsp//linker.x' -msys-crt0='../hal_bsp//obj/HAL/src/crt0.o' -msys-lib=hal_bsp -L../hal_bsp/ -Wl,-Map=nios2_rsu_sw.map -O1 -g -Wall -mno-hw-div -mno-hw-mul -mno-hw-mulx -mgpopt=global -o nios2_rsu_sw.elf obj/default/hello_world_small.o -lm -msys-lib=m
c:/intelfpga_lite/16.1/nios2eds/bin/gnu/h-x86_64-mingw32/bin/../lib/gcc/nios2-elf/5.3.0/../../../../../H-x86_64-mingw32/nios2-elf/bin/ld.exe: nios2_rsu_sw.elf section `.text' will not fit in region `onchip_memory2_0'
c:/intelfpga_lite/16.1/nios2eds/bin/gnu/h-x86_64-mingw32/bin/../lib/gcc/nios2-elf/5.3.0/../../../../../H-x86_64-mingw32/nios2-elf/bin/ld.exe: region `onchip_memory2_0' overflowed by 39528 bytes
Is there a modified remote_update.c that can fit the 10M08 chip? I got the file from the rsu reference project for 10M50. Would I need to modify the remote_update.c and optimize it for 10M08 chip since 10M08 only has 378 Kb of M9K memory whereas 10M50 has 1638 Kb.
Use external memory in you design instead of onchip ram.
Look into AN 730 Nios II Processor Booting Methods in MAX 10 FPGA Devices.
Anand
