8 years agoCan I expect PLL outputs to be in phase?
If I implement an ALTPLL in a cyclon V with an input clock of 26 MHz and 2 output clocks (one at 26 MHz and one at 4x 26 MHz = 104 MHz). Can I expect the two output clocks to be in phase? If...
8 years agoThe output clocks are in phase and synchronous. You don't need the set_clock_groups exception unless you specifically do not want timing analysis performed on transfers between the two clock domains.
