17 years agoCan I change configuration's address ?
hi,all I want to add update function to my EP2C8 + EPCS16 board using rs232 port, I know that the fpga configuration data is stored in EPCS16 from address 0x0, when power on, EP2C8 r...
17 years agothanks
I think I should do these to implement system updating by rs232 : rs232 receive config data and software (flash file) from PC, and store it in sdram, after all bytes are received successful, using epcs hal funtion write config data to epcs16 from address 0, and write software image follow it. then restart system, That's OK ? Any other better idles ?
