17 years agoCan I change configuration's address ?
hi,all I want to add update function to my EP2C8 + EPCS16 board using rs232 port, I know that the fpga configuration data is stored in EPCS16 from address 0x0, when power on, EP2C8 r...
17 years agoOn power-on no. However, using the remote update core, you can specify a different address and trigger a reconfig.
So 1 - On power-on, config data at address 0 will always be booted first. 2 - If you want to boot from another address other than 0, write to the remote update core to specify the new address and trigger a reconfig. Jake
