17 years agoCan I change configuration's address ?
hi,all I want to add update function to my EP2C8 + EPCS16 board using rs232 port, I know that the fpga configuration data is stored in EPCS16 from address 0x0, when power on, EP2C8 r...
17 years agoAs far as programming the EPCS16 device, you may be able to use the Serial Flash Loader megafunction:
http://www.altera.com/literature/an/an370.pdf or you could use the "EPCS Device Controller Core" (SoPC builder based) http://www.altera.com/literature/hb/nios2/n2cpu_nii51012.pdf For loading multiple configurations, you'll need to use the remote update core: http://www.altera.com/literature/ug/ug_altremote.pdf Jake
