Can Cyclone IV PIO Banks at 1.8V Safely Drive 3.3V I2C ICs in Open-Drain Mode?
- 1 year ago
I'd refer to datasheet Table1–3. Recommended Operating Conditions for CycloneIVE Devices, Vi range -0.5 to 3.6 V for all VCCIO values.Open drain means the pin is switched between tri-stated (input mode) and output pulldown. No clamping action involved. Therefore I expect your intended operation should work.
You'll generally take care for possible signal reflections exceeding the safe FPGA input voltage range. Because high level is only driven by I2C pull-up resistors, there's little risk of exceeding it, even with longer traces.Regards
Frank
Frank
