8 years agoCan Arria 10's FMC single-ended signals be more than 2.0 V?
Hi, I'm wondering if I can get more than 2.0V single-ended signals out of the FMC connector on the Arria 10 SOC, which using the 10AS066N3F40E2SG. All FMC pins on this board are connected to ...
8 years agoWithout modifying your development board? No. J42 allows you to set the I/O voltage for that bank, but only as high at 1.8V.
If you wanted a higher voltage in that I/O bank you' have to modify the board. That's fine as far as the Arria device is concerned - 3.0V maximum. It also feeds the MAX V, for which 3V is also fine. You'll need to check what other devices that rail feeds. Cheers, Alex
