AVolo2
4 years agocan arria-10-gx run on aarch64 nvidia jetson?
we got this card
can it work on jetson board?
https://www.intel.com/content/dam/www/central-libraries/us/en/documents/intel-pac-with-arria-10-gx-product-brief.pdf
It is listed in lspc...
JohnT_Altera
4 years agoHi,
For standard installation, it is supporting Ubuntu 18.04. You may refer to https://www.intel.com/content/www/us/en/docs/programmable/683633/1-2-1/system-requirements.html
AVolo2
4 years agoHello
Coud you confirm
That on 18.04 not only opae-sdk installs with linux-dfl from opae repository
But the intel setup script install also installing linux-dfl from dev stack install script, please?
Other Intel folks pointed out that intel dev stack install script doesn't install linux-dfl at any OS as I understand
Moreover installing it manually from opae-sdk results in nothing but in boot error when booting from linux -dfl kernel.
Any ideas?
-BR
AV
