can arria-10-gx run on aarch64 nvidia jetson?
Are you installing the driver from the Programmer Acceleration Stack installer? If yes, then it is not supported. You will need to use the OPAE in the https://opae.github.io/
To clarify:
Installing everything from Programmer Acceleration Stack installer to just reinstalled Ubuntu 18.04 OS is not supported on x86_64? Is it supported in some other specific OS version? Or the support has been dropped for all OS'es?
I have tried installing the driver from the poorly documented open source source https://opae.github.io/ too - it resulted in red error message while booting the linux-dfl; I tried like 12 times already; so rebuilding it again
Could you provide redundant instructions how to get the hello world example running? Which OS is required?
