AVolo2
4 years agocan arria-10-gx run on aarch64 nvidia jetson?
we got this card
can it work on jetson board?
https://www.intel.com/content/dam/www/central-libraries/us/en/documents/intel-pac-with-arria-10-gx-product-brief.pdf
It is listed in lspc...
AVolo2
4 years agopreviously after the minor upgrade but before upgrade to 5.8 it was better;
it was like
lspci -s 07:00.0 -vv 07:00.0 Processing accelerators: Intel Corporation Device 09c4 Subsystem: Intel Corporation Device 0000 Physical Slot: 1 Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx- Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Latency: 0, Cache Line Size: 64 bytes Interrupt: pin A routed to IRQ 16 NUMA node: 0 Region 0: Memory at 80600000 (64-bit, prefetchable) [size=512K] Region 2: Memory at 80680000 (64-bit, prefetchable) [size=512K] Capabilities: <access denied> Kernel driver in use: dfl-pci Kernel modules: dfl_pci
