AVolo2
4 years agocan arria-10-gx run on aarch64 nvidia jetson?
we got this card
can it work on jetson board?
https://www.intel.com/content/dam/www/central-libraries/us/en/documents/intel-pac-with-arria-10-gx-product-brief.pdf
It is listed in lspc...
AVolo2
4 years agoCreating symlink /var/lib/dkms/intel-fpga/2.0.3/source -> /usr/src/intel-fpga-2.0.3 DKMS: add completed. Kernel preparation unnecessary for this kernel. Skipping... Building module: cleaning build area..... make -j4 KERNELRELEASE=5.8.0-49-generic KERNELDIR=/lib/modules/5.8.0-49-generic/build......(bad exit status: 2) Error! Bad return status for module build on kernel: 5.8.0-49-generic (x86_64) Consult /var/lib/dkms/intel-fpga/2.0.3/build/make.log for more information. Kernel preparation unnecessary for this kernel. Skipping... Building module: cleaning build area... make -j4 KERNELRELEASE=5.8.0-49-generic KERNELDIR=/lib/modules/5.8.0-49-generic/build...(bad exit status: 2) ERROR: Cannot create report: [Errno 17] File exists: '/var/crash/opae-intel-fpga-driver.0.crash' Error! Bad return status for module build on kernel: 5.8.0-49-generic (x86_64) Consult /var/lib/dkms/intel-fpga/2.0.3/build/make.log for more information. modprobe: FATAL: Module mtd not found in directory /lib/modules/5.8.0-49-generic modprobe: FATAL: Module spi-nor-mod not found in directory /lib/modules/5.8.0-49-generic modprobe: FATAL: Module intel-generic-qspi not found in directory /lib/modules/5.8.0-49-generic modprobe: FATAL: Module intel-on-chip-flash not found in directory /lib/modules/5.8.0-49-generic modprobe: FATAL: Module altera-asmip2 not found in directory /lib/modules/5.8.0-49-generic modprobe: FATAL: Module i2c-altera not found in directory /lib/modules/5.8.0-49-generic modprobe: FATAL: Module spi-altera-mod not found in directory /lib/modules/5.8.0-49-generic modprobe: FATAL: Module ifpga-sec-mgr not found in directory /lib/modules/5.8.0-49-generic modprobe: FATAL: Module avmmi-bmc not found in directory /lib/modules/5.8.0-49-generic modprobe: FATAL: Module intel-max10 not found in directory /lib/modules/5.8.0-49-generic modprobe: FATAL: Module fpga-mgr-mod not found in directory /lib/modules/5.8.0-49-generic modprobe: FATAL: Module intel-fpga-pci not found in directory /lib/modules/5.8.0-49-generic modprobe: FATAL: Module intel-fpga-afu not found in directory /lib/modules/5.8.0-49-generic modprobe: FATAL: Module intel-fpga-fme not found in directory /lib/modules/5.8.0-49-generic modprobe: FATAL: Module intel-fpga-pac-hssi not found in directory /lib/modules/5.8.0-49-generic modprobe: FATAL: Module intel-fpga-pac-iopll not found in directory /lib/modules/5.8.0-49-generic modprobe: FATAL: Module pac_n3000_net not found in directory /lib/modules/5.8.0-49-generic modprobe: FATAL: Module c827_retimer not found in directory /lib/modules/5.8.0-49-generic ------------------------------------------------------------------------------- - 1. Ubuntu installing OPAE software ... ------------------------------------------------------------------------------- >>> Running cmd: sudo apt-get install ./opae-libs-1.1.2-2.x86_64.deb
