can arria-10-gx run on aarch64 nvidia jetson?
You can download the installation for the acceleration stack from https://www.intel.com/content/www/us/en/collections/products/fpga/software/downloads.html?s=Newest&f:guidetm5E778C79B03E44E9B8E4DD2A75C6DEE3=%5BIntel%C2%AE%20Acceleration%20Stack%20for%20Intel%C2%AE%20PAC%20with%20Arria%2010%20GX%5D.
You may refer to the quick start guide in https://www.intel.com/content/www/us/en/docs/programmable/683633/1-2-1/about-this-document.html
- AVolo24 years ago
does installing the thing below include installtion of the driver/ examples? Or it still require to install separately manually opae-sdk / & linux-dfl driver?
. Installing the Intel Acceleration Stack
- AVolo24 years ago
I was able to build https://github.com/OPAE
How to try the board with it on my aarch64 \\jetson board?
-AV
- AVolo24 years ago
this one during the installation script running would say that it requires x86_64 processor instruction set
The other one which is the method for building from sources, used with ubuntu
which kernel modules need to be built for ubuntu?
could you extend, please? Just building the opae-sdk won't work, will it without modules customly added?
for fedora I can see these steps listed
$ cat configs/n3000_d5005_defconfig >> .config $ echo 'CONFIG_LOCALVERSION="-dfl"' >> .config $ echo 'CONFIG_LOCALVERSION_AUTO=y' >> .configtrying also to build the package [ failed]
~/opae-sdk/packaging/opae/deb$ ./create ubuntutrying to build without packaging
/home/nvidia/opae-sdk/libraries/plugins/vfio/opae_vfio.c: In function ‘vfio_fpgaOpen’: /home/nvidia/opae-sdk/libraries/plugins/vfio/opae_vfio.c:681:2: error: implicit declaration of function ‘__builtin_cpu_init’; did you mean ‘__builtin_irint’? [-Werror=implicit-function-declaration] 681 | __builtin_cpu_init(); | ^~~~~~~~~~~~~~~~~~ | __builtin_irint /home/nvidia/opae-sdk/libraries/plugins/vfio/opae_vfio.c:682:6: error: implicit declaration of function ‘__builtin_cpu_supports’; did you mean ‘__builtin_isupper’? [-Werror=implicit-function-declaration] 682 | if (__builtin_cpu_supports("avx512f")) { | ^~~~~~~~~~~~~~~~~~~~~~ | __builtin_isupper [ 24%] Building C object libraries/plugins/xfpga/CMakeFiles/xfpga.dir/enum.c.o [ 24%] Building C object libraries/libbitstream/CMakeFiles/bitstream.dir/metadatav1.c.o [ 25%] Building CXX object libraries/libopaecxx/CMakeFiles/opae-cxx-core.dir/src/except.cpp.o [ 26%] Building C object libraries/plugins/vfio/CMakeFiles/opae-v.dir/dfl.c.o [ 27%] Building C object libraries/libbitstream/CMakeFiles/bitstream.dir/__/__/tests/framework/mock/opae_std.c.o [ 27%] Building CXX object libraries/libopaecxx/CMakeFiles/opae-cxx-core.dir/src/errors.cpp.o [ 27%] Linking C shared library ../../lib/libbitstream.so [ 27%] Built target bitstream [ 27%] Building C object libraries/libboard/board_common/CMakeFiles/board_common.dir/board_common.c.o [ 27%] Building C object libraries/plugins/xfpga/CMakeFiles/xfpga.dir/error.c.o [ 27%] Building CXX object libraries/libopaecxx/CMakeFiles/opae-cxx-core.dir/src/sysobject.cpp.o [ 28%] Building C object libraries/plugins/xfpga/CMakeFiles/xfpga.dir/umsg.c.o [ 29%] Building C object libraries/libboard/board_common/CMakeFiles/board_common.dir/__/__/__/tests/framework/mock/opae_std.c.o [ 29%] Linking C static library ../../../lib/libboard_common.a [ 30%] Built target board_common [ 30%] Building C object libraries/libboard/board_a10gx/CMakeFiles/board_a10gx.dir/board_a10gx.c.o cc1: all warnings being treated as errors make[2]: *** [libraries/plugins/vfio/CMakeFiles/opae-v.dir/build.make:90: libraries/plugins/vfio/CMakeFiles/opae-v.dir/opae_vfio.c.o] Error 1 make[1]: *** [CMakeFiles/Makefile2:1773: libraries/plugins/vfio/CMakeFiles/opae-v.dir/all] Error 2 make[1]: *** Waiting for unfinished jobs.... [ 30%] Building C object libraries/plugins/xfpga/CMakeFiles/xfpga.dir/reconf.c.o [ 30%] Building C object libraries/plugins/xfpga/CMakeFiles/xfpga.dir/open.c.o [ 31%] Building CXX object libraries/libopaecxx/CMakeFiles/opae-cxx-core.dir/src/version.cpp.o /home/nvidia/opae-sdk/libraries/plugins/xfpga/open.c: In function ‘xfpga_fpgaOpen’: /home/nvidia/opae-sdk/libraries/plugins/xfpga/open.c:147:2: error: implicit declaration of function ‘__builtin_cpu_init’; did you mean ‘__builtin_irint’? [-Werror=implicit-function-declaration] 147 | __builtin_cpu_init(); | ^~~~~~~~~~~~~~~~~~ | __builtin_irint /home/nvidia/opae-sdk/libraries/plugins/xfpga/open.c:148:6: error: implicit declaration of function ‘__builtin_cpu_supports’; did you mean ‘__builtin_isupper’? [-Werror=implicit-function-declaration] 148 | if (__builtin_cpu_supports("avx512f")) { | ^~~~~~~~~~~~~~~~~~~~~~ | __builtin_isupper cc1: all warnings being treated as errors make[2]: *** [libraries/plugins/xfpga/CMakeFiles/xfpga.dir/build.make:146: libraries/plugins/xfpga/CMakeFiles/xfpga.dir/open.c.o] Error 1 make[2]: *** Waiting for unfinished jobs.... [ 32%] Building C object libraries/libboard/board_a10gx/CMakeFiles/board_a10gx.dir/__/__/__/tests/framework/mock/opae_std.c.o [ 32%] Linking C shared module ../../../lib/libboard_a10gx.so make[1]: *** [CMakeFiles/Makefile2:1719: libraries/plugins/xfpga/CMakeFiles/xfpga.dir/all] Error 2 [ 32%] Built target board_a10gx [ 32%] Linking C static library ../../lib/libopae-c-archive.a [ 32%] Built target opae-c-archive [ 32%] Linking CXX shared library ../../lib/libopae-cxx-core.so [ 32%] Built target opae-cxx-core [ 32%] Linking CXX shared module ../../lib/pyopaeuio.cpython-38-aarch64-linux-gnu.so [ 32%] Built target pyopaeuio [ 32%] Linking CXX shared module ../../lib/eth_group.cpython-38-aarch64-linux-gnu.so [ 32%] Built target eth_group make: *** [Makefile:156: all] Error 2
