15 years agocan any one help me in VHDL codes plz
Hi all ,
I wanna help to write these 2 codes of the VHDL on Quartus II programme: 1) a structural VHDL code of 1 to 8 Demultiplexers. with an active low Enable signal using 1 to 2 Demultiplexer. [ use Generate statement] __________________________________________________ ____________ 2) a structure or behavior VHDL code of 5-bits binary counter with a synchronous load signal to preset the counter to a specific initial state. the output of the counter ( Q0 to Q4) are connected to a binary decoder that shows the state of the counter. In our college they did not teach us this programme and they want from us to make these codes in the next 3 days and really i am so poor in the programming, So can any one help me plz :cry:3 Replies
one of my references : vhdl syntax : http://amouf.chez.com/syntaxe.htm with few examples
You don't need procedures and functions, neither package. - Altera_Forum
hi sir,
yes we took a quick intro and the teacher now is in holiday -_- really thank you for that :) - Altera_Forum
Hi, are you french ;-) ?
--- Quote Start --- In our college they did not teach us this programme and they want from us to make these codes in the next 3 days --- Quote End --- Did you go to the courses :-D ? Or your teacher is on hollydays. VHDL is Very High frenquency Integrated Circuit Hardware description language. So, you should have an "intro" to this language. First, make schema (for beginners). Second, describe it in VHDL In Quartus, you have templates. You will find them in Quartus menu. In the Word Wide Web (thanks to the billions of persons who are connected on and can help a poor lonesome student by freely sharing tons of knowledge....) , there are numerous examples. Q1) Not easy for pure beginners first make "n active low Enable signal using 1 to 2 Demultiplexer" Q2) http://en.wikipedia.org/wiki/vhdl
... Good homeworks ! (in my opinon, this is the worst way to learn something) And .......... Good Luck !library IEEE; use IEEE.std_logic_1164.all; use IEEE.numeric_std.all; -- for the unsigned type entity counter_example is generic ( WIDTH : integer := 5); -- 5 here :-) port ( CLK, RESET, LOAD : in std_logic; DATA : in unsigned(WIDTH-1 downto 0); Q : out unsigned(WIDTH-1 downto 0)); end entity counter_example; architecture counter_example_a of counter_example is signal cnt : unsigned(WIDTH-1 downto 0); begin process(RESET, CLK) is begin if RESET = '1' then cnt <= (others => '0'); -- async load elsif rising_edge(CLK) then -- synchronous domain below if LOAD = '1' then cnt <= DATA; -- sync load else cnt <= cnt + 1; end if; end if; end process; Q <= cnt; end architecture counter_example_a;
