xytech
Contributor
7 years agoCan A10 GX transceiver's TX/RX channel be used Independently in Uni-direction dataflow?
Hi there, We use 3 pcs of A10 10AX057H3F34E2SG ( named A, B, C) on one board, with inter-FPGA XCVR links between A&B, and B&C. Every link contains x24 Uni-Direction dataflow, with possibly same data...
- 7 years agoHie YI Xiao, Yes, you may use the Tx and Rx independently. Any limitation on the shared resources between the Tx and Rx of every channels will be flagged error when you perform a Quartus compilation. Hence, please create a design using Quartus Prime Pro and run complation to understand the precautions and limitations based on the warnings, ciritcal warnings and error messages. Our Transceiver Phy Reset Controller IP also offers a feature to separate the Tx and Rx reset to be independent. Regards, Nathan
Nathan_R_Intel
Contributor
Nathan
xytech
Contributor
7 years agoThanks, Nathan, very useful. We use Quartus Prime Standard rather than Pro, can we just verify our design in Standard version?
