16 years agoCalculation of Number of embedded multiplier
Operation: z<= a*b;
Therer are 2 cases below and I need someone to explain on how the number below obtained. Pls explain the reason there are uses of mixed sign, unsigned and signed multiplier since this is just a signed operation. thanks Case1: input signed [31:0] b; input signed [31:0] a; (*multstyle = "dsp"*) output reg signed [63:0]z; Simple Multipliers (9-bit) 0 Simple Multipliers (18-bit) 4 Embedded Multiplier Blocks -- Embedded Multiplier 9-bit elements 8 Signed Embedded Multipliers 1 Unsigned Embedded Multipliers 1 Mixed Sign Embedded Multipliers 2 Variable Sign Embedded Multipliers 0 Dedicated Input Shift Register Chains 0 Case2 input signed [31:0] b; input signed [31:0] a; (*multstyle = "dsp"*) output reg signed [31:0]z; Simple Multipliers (9-bit) 0 Simple Multipliers (18-bit) 3 Embedded Multiplier Blocks -- Embedded Multiplier 9-bit elements 6 Signed Embedded Multipliers 0 Unsigned Embedded Multipliers 1 Mixed Sign Embedded Multipliers 2 Variable Sign Embedded Multipliers 0 Dedicated Input Shift Register Chains 01 Reply
Since the device's multipliers can only handle 18x18 multiplications, larger multiplications are implemented using several partial multiplications, like you learned in school.
Thus, a full 32x32 multiplication requires 4 partial multiplcations. And since the signal is in the MSB, the other parts are handled as unsigned. 1st a[17:0] * b [17:0] - unsigned * unsigned 2nd a[31:18] * b [17:0] - signed * unsigned 3rd a[17:0] * b [31:18] - unsigned * signed 4th a[31:18] * b [31:18] - signed * signed Thus, the mix you're seeing in the report. As for case 2, since you're only keeping the result's 32 LSBs, the 4th term isn't needed.
