16 years agoByteBlasterMV programming with JTAG disabled
I’ve disabled JTAG so I can use the JTAG pins for I/O and used a JBC file to program an EPM7064S using ByteBlasterMV. Using a POF file doesn’t work. As far as I can tell the programming s...
16 years agoIf I understand right, your way of programming is a one way ticket. You can't neither verify nor reprogram the chip. If you want to, you need a programmer that supports a high voltage programming method, e.g. the Altera Programming Unit (APU).
