16 years agoBurst mode of DDR SDRAM
Dear all, I am not very understanding burst mode, we all know DDR SDRAM has burst length of 2 or 4 or 8. Does it mean the transfer data length should be times of 2 or 4 or 8? What is the...
16 years ago --- Quote Start --- Dear all, I am not very understanding burst mode, we all know DDR SDRAM has burst length of 2 or 4 or 8. Does it mean the transfer data length should be times of 2 or 4 or 8? --- Quote End --- For SDR - yes. And you can use full page mode. --- Quote Start --- What is the units of burst length? --- Quote End --- Word. If you use 8 bit SDRAM you burst 8 mean 8 bytes. If you use 4 bit wide burst 8 give you 4 byte. --- Quote Start --- For example, if I have 16 bytes, transfer in a burst length of 2, do I need to issue 8 command read/writes? --- Quote End --- Yes. And you may no need change page. --- Quote Start --- What if my data size is odd? does it mean either I need to repack the data to times of burst length? or tranfer most of the data in burst mode, the remaning data in non-burst mode? --- Quote End --- You can use mask pin in DRAM. It's 8 bit wide pin. En example if you need to write 8 bit data to 32 bit DRAM. You need to mask 3 byes and unmask one byte.
