16 years agoBurst boundaries on Frame Buffer
Hi all. I have many questions about the VIP Frame Buffer. if I want to change the base address of the frame buffer, how do I calculate the burst boundaries? and again.. My image is 512*384 w...
16 years agoYour burst boundary requirements depends on your memory topology. If you are not connecting to a burst wrap slave, you don't really need to worry as much.
However, the simplest way to calculate your burst boundary is multiply the memory width by the burst target (128-bit memory interface with a burst target of 32 would be (16 bytes * 32 words) = 512 bytes. Your burst boundaries are every 512 bytes. If you align on any boundary other than that, you could see out of order memory accesses. Jake
