20 years agobuildroot to build toolchain on Linux
TO_BE_DONE
20 years agoYou can use "free" to find out the memory usage.
You can try the following to reduce the memory usage. 1. The default busybox use more options than you will need. You can reduce the commands or features supported by busybox, only keep those you will use. cd ~/buildroot/build_nios2/busybox make menuconfig make cd ~/buildroot make 2. reduce the kernel, reduce unused driver and file system. cd ~/linux-2.6.x make ...... menuconfig make 3. remove unused files and nodes in rootfs/etc and rootfs/dev in file ~/buildroot/target/generic/device_table.txt in dir ~/buildroot/target/generic/target_skeleton 4. you can delete files at run time when they are no longer in use.
