14 years agoBuilding RBF with SOF and ELF, External SDRAM
Hi All, I am looking for information on how to concatenate a .elf and a .sof file into a single .rbf file. The elf file loads Nios data and instructions into an external SDRAM. Any information/sugges...
14 years ago --- Quote Start --- What's the point of that slow clock in the system? Nios II/f will definitely run on 75MHz, so I'd just use the same clock in all components. Are You using JTAG_UART in bootloader app? E.g. doing a printf() or something? --- Quote End --- I changed all the clocks to 75 except the input of the PLL, did not seem to make a difference. There are no prints in my .hex code, literally just the sys_init, 2 usleeps, and 2 IOWR to the LED to blink the LED. Also in the BSP editor, I have the stderr, input, output set to none instead of JTAG_UART. I did notice something interesting. Kind of confusing, if I...
- Shut off power, turn on power
- Wait for the config to finish, the LED doesn't blink (program isn't running)
- Then program the FPGA in Quartus, the LED doesn't blink (program isn't running)
- Then run the Nios download from Eclipse, the LED starts to blink (program is running)
- Then reprogram the FPGA in Quartus, the LED stops while it's being programmed, then starts blinking again (program is running again)
