15 years agoBSDL of EP4CE6F17 is not correct?
ID of EP4CE6F17 chip not equal to ID in BSDL file ID of chip is 00000000000000000000010001010011 ID in file is 00000000110000000000100101000101 What is not correct file or chip?
15 years agoHi again,
I checked some other parts. There I found the Manufacturers Code you read out of the chip. You should talk back to altera if there is an error in the BSDL for your device. In these two files you can see thecode is equal: http://bsdl.info/view.htm?id=249 http://bsdl.info/view.htm?id=3085 I think you can walkaround if you change the Manufacturers ID in the BSDL by hand to 00001101110.
