19 years agoBoundary Scan Testing MAX II
I'm trying to perform Boundary Scan testing on my programmed MAX II, and I can't seem to sample pins that are configured as outputs, Anyone know why?
19 years agoOr you may try using the BSDLCustomizer. It's a tcl script that modifies the BSDL files according to your PIN file. So, when you run that script, a new BSDL file will be generated and you can use that to test your MAX II with the pins configured as output (even when the input buffers are turned off).
You may get it here: ftp://ftp.altera.com/outgoing/download/bsdl/bsdlcustomizer.zip
