13 years ago
boot configuration files from NOR Flash
hi,
i am using a Cyclone IV device,NOR Flash(PC28700BP30EF),JTAG,EPCS ans a external switch, the arragement is shown in attached figure.
i have to flash two different images(A and B) in NOR Flash. i have to configure my CycloneIV device,when the switch is closed i have to select Image A from NOR flash and when switch is open i have to select Image B from NOR flash.
Is there any possible solutions to do this ......
    Hi Cris72,
    The flash part name is PC28F00BP30E. I am using cyclone IV gx family FPGA.
    As I told, I have two different configuration images to be loaded into my FPGA and i need to select anyone based on a switch kind of thing
    I have the following Questions
    1. In this type of FPGA, is configuration from Norflash possible(i feel it requires AP mode, that s not supported in Cyclone IV GX).
    2. How does PFL supports FPGA configuration ? is it of any use???
    3. Is there anyother possible methods to do it with the available resources as shown in block diagram???
    Thanks and Regards,
    Santhosh
    Why do you need both EPCS and a NOR flash for configuration?
    I can't find that flash part name. I guess it's a parallel flash; then you could possibly connect the switch signal to one of the higher address lines and make a true 'hardware' selection of the image.
    On the other hand the usual solution is using remote update core: you always load a third default configuration, which only purpose is testing the switch status and triggering a fpga reconfiguration with the appropriate image.
