13 years agoboot configuration files from NOR Flash
hi, i am using a Cyclone IV device,NOR Flash(PC28700BP30EF),JTAG,EPCS ans a external switch, the arragement is shown in attached figure. i have to flash two different images(A and B) in NO...
13 years agoWhy do you need both EPCS and a NOR flash for configuration?
I can't find that flash part name. I guess it's a parallel flash; then you could possibly connect the switch signal to one of the higher address lines and make a true 'hardware' selection of the image. On the other hand the usual solution is using remote update core: you always load a third default configuration, which only purpose is testing the switch status and triggering a fpga reconfiguration with the appropriate image.
