10 years agoBoot and Configure Max10 FPGA from external serial flash?
is it possible to Boot and Configure Max10 FPGA ( 10M50SCE144A7G) from an external serial flash memory . Does Max10 support Active serial configuration?
from what I have read so far we can only boot the FPGA from the on chip flash? Correct me if I am wrong. I couldnt find it in any of the documents. Thanks for all the help in advance! Sharu1 Reply
MAX 10 only support JTAG and JTAG in-system configuration. You can boot the FPGA from the on chip flash and you can do normal JTAG configuration on the FPGA too. I do not think MAX 10 supports AS configuration as it is not stated in the user manual. You can refer to this pdf for more information:
https://www.altera.com/en_us/pdfs/literature/hb/max-10/ug_m10_config.pdf
