14 years agoBoard recommendation for MLBS until 60MHz
Hello there! I need to generate a Maximum length binary sequence (MLBS) with an FPGA for a project of mine, which I then have to modulate with a carrier signal. The MLBS needs to be at least 60MHz a...
14 years ago --- Quote Start --- I need to generate a Maximum length binary sequence (MLBS) with an FPGA for a project of mine, which I then have to modulate with a carrier signal. --- Quote End --- Read this: http://www.ovro.caltech.edu/~dwh/correlator/pdf/lfsr_tutorial.pdf (http://www.ovro.caltech.edu/%7edwh/correlator/pdf/lfsr_tutorial.pdf) --- Quote Start --- The MLBS needs to be at least 60MHz and above frequency. I found an old Spartan-3 starter kit and started working on it to try and generate such a signal. --- Quote End --- This is an Altera group, not a Xilinx group, you'll have to ask for help with your board elsewhere. However, to get you started, you should use CoreGen to create a PLL, use the 50MHz as the PLL reference input, and create 60MHz as the PLL output. Cheers, Dave
