16 years agoBlackjack using VHDL code
My partner and I have an assignment to replicate a blackjack game using VHDL coding techniques on Quartus Max+II. We were to do this by using a Finite State Machine. We are having trouble unde...
16 years agoFirst of all thank you both very much for your time and effort, and this really did help me to understand the basics of how to implement a FSM using VHDL.
My design basically uses one process, and one HUGE case statement inside that process. Inside of the case statement I have about twenty when statements. The when statement that you see here seems to be where I am having the problems. Is this a valid When statement?? And if so, will it go through the entire statement in one clock cycle?? Thanks again!!! WHEN hitadd => IF (cardA <= "00001") THEN state <= error2; ELSIF (cardA > "01011") THEN state <= error2; END IF; output <= (output + cardA); charlie <= (charlie + 1); hit <= '0'; IF (cardA = "01011") THEN state <= aceadd; ELSIF (output >= "10001") THEN state <= decision; ELSIF (output < "10001") THEN state <= cchar; END IF;
