uniqueMR
2 years agobitbake_image failed in HPS Example Design for Agilex 7 I-Series DevKit (2x R-Tile and 1x F-Tile)
Hi, I was following HPS Example Design for Agilex 7 I-Series DevKit (2x R-Tile and 1x F-Tile) and failed at the step 'bitbake_image'. I attached the logfile of failure to this thread. Does anyone ...
aikeu
2 years agoHi uniqueMR,
Glad to hear that the connection issue has been solved and by using the pre-built images. You were able to run the program.
I will follow up again with the issue related to bitbake image step from the document.
Aik Eu
uniqueMR
2 years agoNow the 'bitbake_image' problem has been resolved. I'm not sure but the problem might be related to Yocto workflow. The modification I made is to make an extra git commit after customizing linux kernel. This step seems to match the behavior it did when customizing u-boot and solve the problem.
Thank you for your follow up with this issue!
