uniqueMR
2 years agobitbake_image failed in HPS Example Design for Agilex 7 I-Series DevKit (2x R-Tile and 1x F-Tile)
Hi, I was following HPS Example Design for Agilex 7 I-Series DevKit (2x R-Tile and 1x F-Tile) and failed at the step 'bitbake_image'. I attached the logfile of failure to this thread. Does anyone ...
aikeu
2 years ago- aikeu2 years ago
Suppose it is connected with a PL2303TA cable.
- uniqueMR2 years ago
Yeah, I'm using that board, and I find the J15 to connect with PL2303TA.
Also, thanks to the author of this tutorial, Ritesh Belgudri. He sent me the schematic showing the port definitions of HPS UART interface. Now I have successfully established the UART connection and run HelloWorld!
At this point, there's no issue frustrating me, since I can use the provided .pof and .jic files and skip the 'bitbake_image' step. But I will still appreciate it if you can provide any clues on fixing this issue. It might still be an issue as I proceed to deploy my own design.
Thank you so much for all of your help!
Runlong Hu
