bitbake_image failed in HPS Example Design for Agilex 7 I-Series DevKit (2x R-Tile and 1x F-Tile)
Hi uniqueMR,
I will find time and try out the build on my side to see if there is similar error.
Aik Eu
Dear Aik Eu,
Hi! Thanks for your concern. Though the problem is not fully fixed, I find that the programming files are already provided in the document and I'm able to load them into my device following the guidance. So I might choose to skip this step temporarily.
Now I have a new problem. When I tried to build a serial communication, I'm confused about how I should connect my USB-Uart cable to Pin J15 on the board. It's not specified in the document and I could not find any specification on physical pin assignment in datasheets or user guidance. If you succeed while trying on your side, could you take a picture of the physical connection and the serial console configurations?
Thank you so much for your help!
Best,
Runlong Hu
