bitbake_image failed in HPS Example Design for Agilex 7 I-Series DevKit (2x R-Tile and 1x F-Tile)
Hi uniqueMR,
I will find time and try out the build on my side to see if there is similar error.
Aik Eu
- uniqueMR2 years ago
Dear Aik Eu,
Hi! Thanks for your concern. Though the problem is not fully fixed, I find that the programming files are already provided in the document and I'm able to load them into my device following the guidance. So I might choose to skip this step temporarily.
Now I have a new problem. When I tried to build a serial communication, I'm confused about how I should connect my USB-Uart cable to Pin J15 on the board. It's not specified in the document and I could not find any specification on physical pin assignment in datasheets or user guidance. If you succeed while trying on your side, could you take a picture of the physical connection and the serial console configurations?
Thank you so much for your help!
Best,
Runlong Hu
