18 years agobit by bit Data transfer
Hello All.. I have problem in my code. I have created code for transmitting the data bit by bit. i.e.if my input (FCH)=1010101010101010=AAh then I'm Expecting 1010101010101010=AAh at tx_line o...
18 years agoWithout considering the question, if it's a meaningful application, I corrected your code by keeping the original structure as far as possible:
process(clk)
variable mux_sel:std_logic_vector(2 downto 0):="000";
variable i: integer range 0 to 63;
begin
if (clk' event and clk='1') then
if (rst_n='0')then
tx_line<='0';
mux_sel:="000";
i:=0;
end if;
case mux_sel is
when "000" =>
tx_line<=fch(i);
i:=i+1;
if i > fch'high then
mux_sel:=mux_sel+1;
i:=0;
end if;
-- continue respectively
end case; See the full design as attachment. I understand, that a frame sync character is used, so the data could be possibly received without additional synchronisation. Regarding Stefaan's question, if the baud rate is actually intended to be full clock speed, I think it basically could be. I have a sensor interface using a 40 MHz UART frame from a MAX II device, but it uses a 320 MHz clock at the receiving FPGA. (160 MHz would be a minimum). As Stefaan mentioned, the input has to be stable during transmission for consistent data. I also expect a lower resource requirement using a shift register, but in any case a lot of LEs is needed as multiplexer. If the timing constraints can be met with the existing construct, it must not necessarily changed. Frank P.S.: In case of a synchronous transmission, the frame could be received with the same clock.
