REics
4 years agoBinary compatibility of config files between EP4CE40 and EP4CE55
Due to availability issues, I considering using EP4CE55 instead of EP4CE40 for an existing design.
Do the EP4CE40 binaries (*.rbf files) run without modification on the EP4CE55?
- 4 years ago
I have tested and using the same binary file does *NOT* work. I had to generate the bitstream files individually for each part.
REics
4 years agoI have tested and using the same binary file does *NOT* work. I had to generate the bitstream files individually for each part.
