14 years agobig design uses few resources
I compiled a design a few days ago with a Compilation Report like this: Combinational ALUTs 52,437 Memory ALUTs 0 dedicated logic registers 31,310 T...
14 years agoIf you set output pins to virtual, it will assume you will connect it to something later and keep it there. It wont be of use for a real system though - you will have to connect it to something to run it on a real chip. but at least you can check the resource usage.
