19 years agobidirectional pin simulation for serial I2C
I have problems with bidirectinal pin simulation for serial comunication, problem is there that simulator didn't show writes to SDIO inout pin and also don;t show read from this pin I created...
19 years agoFor me it is strange, that you perform read and write to SDIO at the same time. I was using bidirectional pins. VHDL description looks like this:
IO <= output when OE = '1' else (others => 'Z'); Controlling the OE signal you can change the direction of IO pin/bus. As for simulation, you can observe data out , but reading from IO is practically impossible.
