11 years agoBeMicro Max 10 - DAC 5681 Out pin problem
*Posting again, because first thread just became a blank page. Hello, this is my first post in this forum, so if I make some kind of mistake, just let me know.<br> I'm trying to use t...
11 years ago --- Quote Start --- If you look the DAC datasheet you see it has five input signals and just one output signal, so we can just think there is a mistake in the template given by altera. --- Quote End --- No, there is just a mistake in your thinking. The DAC has a data sheet showing its *INPUTS* and the FPGA is controlling that DAC, so it drives *OUTPUTS* that connect to the DAC inputs. Draw yourself a block diagram and it should become clearer. Cheers, Dave
