11 years agoBeMicro Max 10 - DAC 5681 Out pin problem
*Posting again, because first thread just became a blank page. Hello, this is my first post in this forum, so if I make some kind of mistake, just let me know.<br> I'm trying to use t...
11 years ago --- Quote Start --- So I tried to look again in the board and I found where is the pin, there is a big pin with upper case letters DAC_OUT, the problem was the datasheet of the board doesn't talk about that. Hi! Allow me to direct you to https://cloud.altera.com/devstore/board/bemicro-max-10-fpga-evaluation-kit/ this is what we call the Design Store. If you look under this link you will find the BeMicro MAX 10 "baseline" design. Follow the instructions to download and install this design. Quartus will then be preloaded with the complete pinout for the BeMicro MAX10. You should not have to enter the pinout manually. Cheers Larry
