11 years agoBeMicro Max 10 - DAC 5681 Out pin problem
*Posting again, because first thread just became a blank page. Hello, this is my first post in this forum, so if I make some kind of mistake, just let me know.<br> I'm trying to use t...
11 years ago --- Quote Start --- You're looking at the FPGA pin assignment details, rather than the schematic level details. As far as the FPGA is concerned, the interface to the DAC is via output-only pins. If you find and download the schematic for the kit you are using, it should contain details on how to access the Vout pin. Cheers, Dave --- Quote End --- Thanks for your reply Dave. I already checked the DAC schematic for the kit: http://www.alteraforum.com/forum/attachment.php?attachmentid=9876&stc=1 So when I saw this schematic, I realized I need to measure the pin in the board to see the analog output, because there isn't any pin associated with the DAC_OUT in the schematic. But I thought this isn't the best way to see the output, maybe there is a way to redirect the DAC_OUT to a GPIO pin.
