11 years agoBeMicro Max 10 - DAC 5681 Out pin problem
Hello, this is my first post in this forum, so if I make some kind of mistake, just let me know. I'm trying to use the DAC AD5681 that comes with the board BeMicroMax 10, but I'm hav...
11 years agoThanks for your reply.
I saw the datasheet of the DAC and I thought the template was wrong, as you said. Because this template was provided by altera, not made by me. So I tried to look again in the board and I found where is the pin, there is a big pin with upper case letters DAC_OUT, the problem was the datasheet of the board doesn't talk about that. Thank you again, just a begginer mistake.
