11 years agoBeMicro Max 10 - DAC 5681 Out pin problem
Hello, this is my first post in this forum, so if I make some kind of mistake, just let me know. I'm trying to use the DAC AD5681 that comes with the board BeMicroMax 10, but I'm hav...
11 years agoThe Vout pin (which is there - on the AD5681) drives the resulting analogue voltage generated by the DAC. It doesn't connect to the FPGA, only to a test point (TP1) on the board.
The five pins you list below (from the board datasheet and VHDL template) are all output signals from the FPGA. The DAC has five input signals, which these five FPGA pins drive. So, I think you've misunderstood this aspect of the board a little. Regards, Alex
