15 years agobeginning with CPLD's
hello. I want to start with CPLD's like the title said, but i have absolutely 0 experience with them. I ordered an Altera USB blaster and i am designing a CPLD board. I am going to start wi...
15 years agoHmm to bad, i was hoping to fit an CPLD, jtag header and a crystal on a MBED size board.
(i would link an image to an MBED here but i cant, need 5 posts first, if you dont know it, google it :D) But making that single layer is impossible it seems I'll go for an arduino sized PCB then and imma use my awesome dual layer technique. Making 2 single layer PCB's and glue them together as i can only etch single layers at home. Don't worry, if the prototype works I'll make some professional. For the decoupling caps, is 1 cap per side (4 total) enough, 100nF caps? Or do i need to add tantalum caps to? Little question about the crystal, as the I/O pins are 5V tolerant, can i use a normal 5V crystal? I am planning on just making a schematic with logic blocks and upload it in the CPLD. So connect the crystal to 2 random I/O ports and then make a multiplier/divider and just select the 2 I/O pins as input for them? Or do i need to connect the crystal to specified pins? Thanks for the help, Rik
