19 years agoBeginner question: FPGA timings
I'm very new to the FPGA world, so my question is probably naive. So, I chose a very standard Cyclone II EP2C20F484C7N device. I created a very simple design, and found that the latency fr...
19 years agoBrad's summary is great. if you don't need a single clock cycle Tpd, you get the fastest performance clock frequency using flip flops in the I/O element. If you do need the fastest Tpd from input pin to output pin, sometimes the tools do not do a great job without a little help. If you haven't already, constrain the input and output pins next to eachother. It sounds like you are already asking for a fast as possible time with timing constraints.
